Calc Question
Alwayslearningelec
NJ
Estimator
Think I have a big problem. I hope not. They want me to feed 100A guard booth panel from the 60A LP-1. I did not bring over a 100A feed. I only brought over circuits for the 7.9A FLA but those are for the full load amp for the branch circuits.
Do I really need to run over a 100A circuit? Also I don't think the 60A panel would have enough power.
If your feeder supplying the panel is protected by a 60 amp breaker it does not matter what size (rating) panel you have at the guard booth (60 amp, 100 amp, 200 amp, etc.)
With a 7.9 amp load why would you think a 60 amp would not be enough ?
Not sure what this means? Did you bring a 3Ø, 60 amp feeder to the panel as per your drawing? Also your first graphic is for a 1Ø, 120/240 volt panel. Is this the same panel in both graphics they appear to be different?
I only brought over one 30A circuit to each guard booth. I was worried when I say the guard booth panel was rated at 100A thinking I needed to run a 100A circuit to the panel.
You posted two different graphics which one is correct? A 30 amp circuit probably isn't going to work the LP-1 in the second one.
The 1st pone with the 7.9A is the panel in the guard booth. The other 60A panel(LP-1) is what they want to feed the guard booth panel. They don't show the circuits from LP-1 to guard booth but just say to use spare circuits.
Shows 5 heat trace circuits, but no load calculation included for them. Most guard shacks I'm familiar with have a window A/C or a fan at a minimum?
Got it, so the second graphic is irrelevant to the discussion. Since the panel is fed from 208 volts source and not a 240 volt source their calculations in the first graphic could be slightly off.
As long as I don't need to bring 100 circuit that panel with only two circuits and total 7.9FLA.
