Jaybird77
- Mesa, AZ, USA
I was wondering if anyone can tell me how amperage is calculated in regards to the voltage drop formula. For a designed circuit do you calculate off actual volts to be used without regard to what size breaker is used? Or would you have to use the available amperage according to breaker size? If voltage drop was calculated off of a expected 10A usage but extra lights were added to a circuit since a 30A breaker was installed it would change the end of line voltage drop (assuming the circuit length was not extended).
