AJones
- Houston Texas
- Maintenace Electrician
When using an amp meter on parallel runs load side on a 600 amp disconnect is it accurate to read each leg, L1 a + b etc to calculate total amps?
Or do I need to read all parallel runs per each leg together. I added each cable on each phase together to give my total. example: L1 a=105 b=65 Total 170 amps,
also repeated L2 and L3.
