If I use table 220 to calculate the load on a critical branch panel in a hospital, can I reduce the required load by the portion of the load that is on the critical branch?
For example, 2VA/SF is required for a hospital lighting load. But less than half the lighting is on the critical branch. So can I use 1VA/SF for the critical branch, and assume the other 1VA/SF is provided by the normal panel?
Steve
Steve
