On a 450/120V delta system where on windings A, B & C, 2.25, 2.4 & 2.2 kVA are connected respectively. What is the equivelant 3 phase kVA or kW that is seen. Based on these numbers, (3) 3kVA transformers were selected (loading not more than 80% of winding rating). Ratings of the single phase equipment connected to the transformer create this unbalance. The loads are connected to the transformer to provide the closest possible loading. Is it possible to sum single phase kVA loads and 3 phase kVA loads to acquire a system total kVA. The attempt is how to calculate the loading at the 450V panel supplying mulitple transformer delta loads.
