Hi, I'm looking at a rehab project, a small special use building (carwash) with a 240V 400 amp 3 phase service. We're trying to avoid upgrading service and this appears to be very tight. Before I consult the electrical contractor I wanted to get a rough idea of our real needs. Currently, if I add up all 3 phase motor loads for the proposed new equipment the total is 295 amps. Left in the mix are the single phase items found in every small commercial building (lighting, HVAC, etc). My question: when evaluating single phase loads on three phase service, is an "amp an amp"? For example: if my 110V lamp fixture (continuous use)uses 1.3 amps, do I add that number to the total load, or is there a formula used to reduce that number for load calculations?
Also, does anyone have any recommend reading on the subject, something easy to understand that might assist me in learning more about this topic?
