oldsparky52
- Wilmington, NC USA
Theoretically, if you have a 120/240 Delta supply and load it to 10 amps on L1/L3 and 20 amps on L2/L3 (nothing between L1/L2), what would the amperage be on the L3 conductor (I'm assuming L1 will have a 10-amp load and L2 will have a 20 amp load)?
My understanding is you take the common current (10-amps) and multiply by 0.866 then add in the difference in the currents which is 10-amps. The would be 8.66+10 for 18.66 amps on L3.
I've been told I'm incorrect. What is wrong with my thinking?
