meo1
- Reading, PA
I need to calculate the voltage drop in a 13.8kV circuit. I know that I should take into account reactance in a medium voltage circuit but I am not sure how to do it. If I use the following formula from Mike Holt's "Voltage Drop Calculations" article on his website:
VD = (1.732 x K x I x L)/CM
I know that I need to adjust the K (Direct Current Constant) but I am not sure how to do it. According to the article, for a 600 volt circuit I would multiply K by and "Adjustment Factor" which is calculated by dividing the ac ohms-to-neutral impedance from NEC Chp 9 Table 9 by the dc resistance of NEC Chp 9 Table 8 for the conductor I am interested in using. Does this also apply to medium voltage calculations?
