Flicker Index
- Pac NW
- Lights
90V DC motors are common and are intended to be thyristor controlled off bridge rectified 120vac mains. For simplicity sake, ignoring the foward voltiage drop, what is the math behind 90v DC output? Is that 90v DC average or RMS?
I would think that output (ignoring the 2 x VF drop of 2-3v) would still be 120V RMS, or in other words, 120v 600W heating element would still absorb 600W of real power when fed through a rectifier, but if fed from a 90v battery, it would only operate at 56% power. (90/120)^2.
Does a 90v DC rated motor fed on a 90v battery pump the same cfm of air against a constant torque load (same psi diff) as when its powered from 120vac through a bridge? @Jraef
