Ohms law
- Sioux Falls,SD
Currently the customer has a 480v 3ph 400 amp service to meter then splits to 2-200 amp fused disconnects with 200 amp fuses that feeds 2-480v 3 phase 200amp industrial receptacles.
The customer wants to add 4 more receptacles. Each nameplate states 480v 3ph 18kw, requires mca 150amps.
The customer also states that they would never run more than one truck at a time do to maintenance and testing at which they run no more than 50 amps with lighting, AC, and essential loads (cooling system for imaging machine).
How would one calculate new service size?
Sent from my iPad using Tapatalk
