Muhammad Arshad
New User
- Cleveland
- Design Engineer
- Two commercial photovoltaic modules have the following nameplate specifications under standard test conditions:
[TD valign="bottom"]
Specifications
[/TD][TD valign="bottom"][/TD]
Model-A
Model-B
Maximum Power
Pmax
235
220
Watts
Voltage at maximum power
Vmpp
30.1
29
Volts
Current at maximum power
Impp
7.81
7.6
Amps
Open-circuit Voltage
Voc
37
36.2
Volts
Short Circuit Current
Isc
8.5
8.4
Amps
Temperature coefficient of Isc
isc
0.053
0.065
Temperature coefficient of Voc
voc
-0.351
-0.36
[/TD]STC: Standard test conditions - irradiance of 1000W/m2 at an AM1.5G solar spectrum and a temperature of 25°C. Using the above data:
Obtain the following 5-parameters for the two PV modules under reference conditions
I) IL: The light current
II) Io: The diodes reverse saturation current
III) RS: The series resistance
IV) RSH: The shunt resistance
V) a: The modified ideality factor a
b) Predict the power output and efficiencies of the two panels under 800 W/m2 and 47.5 0C.
