calculation
MGA
New member
What is proper size wire, disconnect, and Breaker for a 480VAC 3 phase motor with a full load amperage of 27 amps?
Re: calculation
Try to do it yourself, and post your results here.
Out of curiosity, might you be checking on some one elses work?
Roger
Re: calculation
What does a "biomedical engineer" need to know this for?
Start at in Article 430 at Part II, then go part IX, then Part IV. Give it a try as Roger suggested.
Re: calculation
Let me point you to the appropriate code sections.
FLA- table430.250
Wire size- 430.22 & 310.16, 310.15(B)(2)
Disconnecting means- 430.110
OCPD- 430.52, 430.58, 430.62
___________________
Wes Gerrans
Instructor
Northwest Kansas technical College
Goodland, KS
