Hello all. I'm trying figure out in my calculation, should I include .30amp an electronic ballast with 3tube 2x4 fixture. If 3 tubes draw 96watt, should I include .30amp ballast which will be 83.1watt. So the whole fixture should be counted as 179watt? Voltage is 277v.
Thank you in advance for the input. It does sound like a lot for 1 fixture especially when you figure continues running, which only gives you 16amp to play with?
Maintenance guy...
Maintenance guy...
