junkhound
- Renton, WA
- EE, power electronics specialty
Just curious what others who need to do complex system analysis are doing:
Has anyone, other than helping a grandkid with homework, actually needed to solve a differential equation or use calculus in the last 10 years? 60 years ago pocos had big analog computer setups for system analysis, am not aware of any of those still in existence?
Think the last I actually did a differential equation solution for a dynamic electrical system response solution was 45 years ago, from then till late 80's still used Laplace; after mid-late 80's have pretty much only used FEA methods and programs. There are a few simple structural and thermal problem still use just simple math.
Calculus similar time frame.
A simple voltage drop question thread brought this to mind. A string of constant current loads is simple addition, constant power loads a bit more complicated, and 3 phase with PF a bit more. Once into RLC circuits with active elements then simple math becomes exceedingly cumbersome even with spreadsheet.
For a quick answer to the poster on the volt drop question it took only 2 minutes to put the question into PSpice and get an answer for constant power loads; would have had to solve 5 quadratic equations for the constant power load situation. The constant current string case one can do in one's head.
In reflecting realize I've forgotten how to even setup a differential equation circuit analysis solution without recourse to 55 YO textbooks, too easy to use Matlab or PSpice for exact answers.
What are your go-to FEA programs? -- mine are Orcad PSpice for circuits and Maxwell 3D for thermal, fields, electrostatics, and combined systems.
