Sierrasparky
- USA
- Electrician ,contractor
How many folks here know about how Ca adopts code?
Do you know we are in the cycle to adopt the 2017 NEC by end of 2019 , with an effective date of Jan 1 2020?
Submittals now and Comment time is this summer. Now is the time to place comments for the amendments. The do listen and consider properly formatted requests for changes.
Did you know that this is a state wide adoption and local jurisdictions must file amendments or they are not enforceable. Further that local amendments can only be more restrictive and allowable only under the following conditions:
Must be for a climatic reason
Must be for a Topographical reason
Must be for a Seismic reason
These are the only conditions for a change to the state building codes (standards) no exceptions.
Adoption calendar here -
http://www.documents.dgs.ca.gov/bsc/2018TriCycle/2018TriCycleTimeline-v01-03-2017.pdf
