pgrovetom1
- Sonoma California
- Telecom System Engineer
When neither a ground mount solar string array and the inverters are located within 50 ft of a building ( both outdoors), are panel rapid shutdown devices required in California. The solar array is mounted on a gentle hillside on a steel frame with 18" underground conduits carrying the DC string pairs to the Inverter. The Inverter has a built in and labeled DC disconnect. The inverters are mounted on a pressure treated wood post structure similar to the utility post intended to provide some sun/weather protection and a place to physically mount the inverters and there are 3 Tesla Powerwall2's mounted on a concrete pad. The PG&E utility power arrives underground to a 4x6" pole mounted 400A panel which acts as the place where the inverter/battery system meets the AC wires that go to the home via underground approximately 50 ft conduits that have multiple sub-panels inside the home. The AC power from the inverter/Powerwall2 battery system are carried via a trough system to the utility 4x6" post. The utility comes up the 4x6" post up from underground. The AC for the home goes via conduits down the 4x6" post and underground to the home. So neither the inverters nor the ground mount solar arrays DC penetrates the home in any way. It does not come within 50 feet of the home. Only the AC from the utility or inverters penetrate the home via conduits as it was before the solar was installed. The NEC language suggests this situation does not require a rapid shutdown function for the solar arrays.
This system was permitted and built in 2019. The reason I am asking is I'm thinking of adding an additional ground mount array and another inverter. If I do this will it now require the array rapid shut down function given there has been 2 NEC updates since 2019 with slightly different language. thanks
