- Bremerton, Washington
- Master Electrician
Is there a requirement for all new housing in CA to have solar or something similar?
OK, I took a quick look at what I believe is the latest draft of the 2019 CEC. The prescriptive requirement for PV is very significant, in my climate zone the prescriptive size for a single family residence is given by:
Minimum DC Watts = 1120 W + 0.628 W * (conditioned square footage)
There are exceptions for insufficient unshaded roof area, a central PV system for a multiple unit development, etc. And with the computational compliance approach, you can still reduce the size of the PV by making improvements elsewhere in the energy budget.
Cheers, Wayne
Cheers, Wayne
I believe this webpage has the latest draft (the adopted draft?) of the 2019 Energy Code, but I haven't studied the adoption process to be certain of that.First of all, thank you for this info. So far I've only gathered some notes for further research on this subject. Can you point to particular energy code sections to back this up?
What I meant was that the requirement seems to me large enough that it would be very difficult to comply under the performance based option (the computational option) with absolutely no PV and just making up the difference elsewhere in the energy budget. Although I haven't played around with the 2019 compliance software yet to verify that.Perhaps your 'very significant' comment lacks some context needed to understand what you mean, but for a 2000sqft home that would be a 2376W system which is the about the minimum size my company would sell. (8 @ 300W panels, for example) So at least in that sense it doesn't seem 'very significant'.
