California Title 24 requirements
Does California Title 24, or any other applicable code, require the light and the exhaust fan to be switched separately for a bathroom ceiling unit? Would this bathroom ceiling unit light be required to be controlled by a dimmer? And, finally, would AFCI protection be required if installing a new bathroom ceiling fan/light unit required extending a lighting circuit?
The electrical code does not require that. There might be something in the energy code.
I very much doubt that.
If it's extended 6ft or more then yes.
Does California Title 24, require the light and the exhaust fan to be switched separately for a bathroom ceiling unit?
Yes
CEC-CF2R-LTG-01-E (Revised 10/16)
150.0(k)2B: Exhaust fans are switched separately from lighting systems, or can be switched OFF in accordance with EXCEPTION.
No
150.0(k)2J: In bathrooms, garages, laundry rooms, and utility rooms, at least one luminaire in each of these spaces are controlled by a vacancy sensor.
See 2017 NFPA-70 210.12(A)
