cgood1976
- el paso, tx
Just a few questions...
1) Can a PTZ camera wire be pulled in a light pole with no conduit?
2) Is it legal to have a conduit for that PTZ camera wire in the pole form the mounting point down to the hand hole with roughly a 10" sepperation from the conduit in the concrete base?
The last question is more of a would you do it...
3) The drawing shows to run 1" conduit for the camera, these are reused poles ( 4X4 and 5X5 ). For the size of the connector ( 1" XTRA FLEX ) it needs a 2 1/4" hole in the pole. Would this considerably weaken the pole or would you feel it safe to make that big of a hole, keeping in mind there is another box for the power for camer with a 1 1/8" hole on pole as well?
