Can 2 cables crimp in one lug?
a.bisnath
Electrical worker
Can 2 cable crimp into one lug?Is this allowable by the codes,of course the lug is to have the the suitable bore to have a snug fit for the two cables and not be slack.
K8MHZ
I doubt there is any crimp type lugs for two cables.
Something like this will probably have to be used:
petersonra
Northern illinois
engineer
Normally I would say no. However, you might be able to find an exception to this general case.
In some respects you are not asking a specific enough question so giving you a specific answer is difficult.
petersonra
Northern illinois
engineer
I totally missed the crimp part.:ashamed1:
I thought OP wanted to put two cables into one mechanical lug.
They make ferrules for crimping two wires together but the largest I ever ran across was #6 I think. They are not really lugs either, and I don't think they are UL listed.
a.bisnath
Electrical worker
can this be used for motor termiation?
When a motor is being terminated and the motor has 6 wires and it is configured for delta,3 pairs of leads needs to be arranged,can each pair be crimped into one lug?
ActionDave
Chief Moderator
Durango, CO, 10 h 20 min from the winged horses.
Licensed Electrician
Can they? Yes.
Should they? Depends. Probably not, however, I have been known to do what it takes to get things running and not suffered any negative consequences.
Coming forward with some more details would be helpful.
cad99
ND
I have used these before when push comes to shove. But I put two under a lug if I have to get it working on the spot.
Living the dream one nightmare at a time
Jraef
Moderator, OTD
Electrical Engineer
You could use an in-line crimp C tap to put pairs together, then take the single tap into a crimp lug. It takes a special crimp tool for the C tap, so you have to weigh the cost of the tool against how many of these you are going to do.
cad99
ND
Would not a Polaris style connector work. Or is crimp connections speced?
