Stevenfyeager
- United States, Indiana
- electrical contractor
I noticed 4/0 SER (4/0 x 3, and one 2/0) doesn’t downsize the neutral, can I downsize the neutral when using single conductors in pvc? Thanks
If the calculated neutral load per 220.61 is under the ampacity of the 2/0 Al (135A typically), sure.I noticed 4/0 SER (4/0 x 3, and one 2/0) doesn’t downsize the neutral, can I downsize the neutral when using single conductors in pvc? Thanks
Like Wayne says technically depends on the neutral load calc. In practice, I pretty much never do a neutral load calc and almost always go two sizes down for the neutral.I noticed 4/0 SER (4/0 x 3, and one 2/0) doesn’t downsize the neutral, can I downsize the neutral when using single conductors in pvc? Thanks
I use AL MC all the time for feeders in commercial applications. It's a big labor saver for sure. It is fine run exposed most of the time.Thank you for your help. I don't do much commerc. work. I recently ran all mc in a warehouse/store, but the biggest I have run was MC 6-3.
Should I consider running a 4 wire 4/0 MC from one of the meter disconnect combos to about 80 feet to a sub panel ? I've never ran conduit that large. Would it be easier or cheaper than conduit ? I see 230.50 B (1) and (2) (2) mentions using MC, but 230.50 B (1) does not. Am I allowed to use MC because this is not a service entrance cable, but "other than service entrance" cables ? (to a sub panel ) I see 4/0 -3 with #2 G MC on line for $10/ ft
Thank you so much !
I've only used 12-2 MC to 6-3 MC, how do you cut the jacket on 4/0 MC ? Is there a special cutting tool like for small MC ? Thank youI use AL MC all the time for feeders in commercial applications. It's a big labor saver for sure. It is fine run exposed most of the time.
Same as smaller MC: kink, untwist and cut with klein 1104's.....or, especially for larger sizes, you can slice the armor with a fine sawzall blade, untwist it and pull it off.I've only used 12-2 MC to 6-3 MC, how do you cut the jacket on 4/0 MC ? Is there a special cutting tool like for small MC ? Thank you
The old guys would use a hacksaw. You cut the same as a roto. I use a roto when I have to but dislike them vs diagonals.I've only used 12-2 MC to 6-3 MC, how do you cut the jacket on 4/0 MC ? Is there a special cutting tool like for small MC ? Thank you
FYI the 1104's make a much nicer cut. I advise getting a pair if you don't have one, they come in handy for lots of other things too.The old guys would use a hacksaw. You cut the same as a roto. I use a roto when I have to but dislike them vs diagonals.
