You've probably seen the 100A RV panels that have 50/2, 30/1, and 20/1 breakers and respective 50A, 30A, and 20A receptacles. These panels have "loop lugs" which allow them to be daisy-chain wired from panel to panel. An electrician would like to loop feed multiple panels from a 200A breaker using 200A wire. My concern is that the lugs of the panels are only rated at 100A (although they can accept 350kcmil wire) and would not be adequately protected with a 200A breaker. Opinions?
