2Htm
- California
- Inspector
Hello to All,
Is it safe and/or an acceptable installation method, in California, to install a Type1 Enclosure subpanel on the exterior directly behind an access metal door/cover that appears to protect against the rain?
The subpanel is installed approximately one inch behind the stucco cladding. The metal access/cover door, equipped with hinges, is subject to all weather elements, no overhead/no eaves, and is lifted upward to allow access to the subpanel's door to open 90 degrees.
Thank you!
Thank you!
