I studied a substation which was connected to the power grid in two voltage levels. In order to separate the substation from the grid, I will need two different voltage level equivalent Thevenin circuits connected to the substation for study. How can I make one external power grid into two Thevenin equvalent circuits and connect them to 230KV and 6.9kV buses of the substation individually? (ETAP can't fault on two bus simutaneously. I have tried open the substation from grid and run the short circuit study individually on the 230kV and 6.9kV and got two kVA and X/R. But this method is not correct.)
