Flicker
- Washington
Hello:
I have an apartment building where I periodically run new circuits to add a washer, dryer and dishwasher.
I have been running the new NM in the crawl space and I have been attaching the NM to the bottom edge of the joists.
I just read in 334.15(C) Exposed Work:
(In Unfinished Basements and Crawlspaces. "Where cable is run at angles with joists in unfinished basements and crawl spaces, it shall be permissible to secure cables not smaller than two 6 AWG or three 8 AWG conductors directly to the lower edges of the joists. Smaller cables shall be run either through bored holes in joists or on running boards."
The crawl space is quite low at only about 3 feet high. And also, the only access to the crawl is through a screened small access hole in the foundation which only a maintenance person would choose to squeeze into.
I was wondering what 334.15 (c) was attempting to protect against?
I have read about the risk of someone using the NM as a clothes line or it receiving an impact, but in my situation, there is not enough height or access for either of those things to happen.
When I run these circuits, I would prefer not to have to install running boards, or have to drill holes in the joists along an indirect route since running the NM the most direct route is physically painful enough as I have to crawl on my stomach from often a distant access point to where the wire needs to go.
Does the code allow attaching on the ends of the joists in such a low and hard to reach location?
If not, what is the code trying to protect against in this situation?
Thanks.
Thanks.
