dmanda24
Hello, I am doing a job for a printing company, where they need to install a particular used printing press, to make it easy I will list the facts (numbered)and issues(lettered):
1) The machine runs on 3 phase 480 V
a) There is only 3 phase 120/208V coming in to the building, transformer needed.
2) The main panel for this used machine was fed with size 500 wire with a 400 A disconnect
b) Given the size of the wire the maximum load should be 252KVA so the use of a 300 KVA 240/480 D/Y transformer is required, pretty expensive.
3) The owner has two identical 3 phase 240/480 D/Y 150 KVA transformers
4) Can these two transformers be connected in parallel to achieve the needed KVA for the equipment.
If so are there any special considerations?
How would the overcurrent protection be for these parallel transformers?
Is the KVA rating just simply additive?
Any special way to ground the two transformers?
Any help would be greatly appreciated.
Daniel.
Daniel.
