In a control panel I am using 2 distribution blocks. The power coming in is fused at 250A in a separate disconnect enclosure and wired into the first distribution block using #250kcmil wire(this dist. block has 2 sets of input terminals).
I want to wire the second distribution block input power from the first block's second set of terminals.
If I figure the total amp draw used in the outputs of the second distribution block & multiply by 125% it comes out that I need #2/0 wire for the input into the second distribution block. However, the only previous circuit protection would be the 250A fused disconnect.
I have a colleague who tells me this is acceptable, but I can't find it in the NEC book.
Any help is definitely appreciated.
Thanks.
Thanks.
