Can I ignore 310.15(B)(7)(c)?
de2
Newark, NJ
I am sure all of you have one or more objections to NEC. And I do definitely have one; 310.15(B)(7)(c).
Single family residential, calculated load is 135A.
Here is what I want; 150A OCPD with 1/0 cable (75C).
I don't feel comfortable using 310.15(B)(7)(c), 135*0.83=112A, selection #1 awg with 150A OCPD. Why would you choose OCPD based on calculated load but feeder with 0.83?
Why not chose OCPD and feeder together 0.83? Or just erase 0.83?
I see a benefit 0.83 gives, smaller cable, economical, but why keep OCPD still at %100?
I just dont get it.
I just dont get it.
Your calculation is incorrect. It's 83% of the service rating not the calculated load.
In this case I think you still end up with a #1. 135 amp calculated load =150 amp service 150 X .83 = 124.5 = #1 but that is the same case as it was u8nder the "old" rule.
Remember the NEC is the MINIMUM.
Yes the service overcurrent protective device in your case would be the service size.
For instance a 200 amp service would need a conductor capable of handling 166 amps-- 2/0 copper would work
is there any logical explanation that you put a smaller cable than ocpd? I just dont get it.
