Can I solder this wire?
Buck Parrish
NC & IN
It is a wire that looks like a spring wrapped around nylon string.
It must be a heating element for a bird bath.
In this pic I stretched the outer wire.
Will it still heat if I solder it?
... or Campfire? Kidding aside, we'd need to know what you intend to solder. That picture is really small, but if the problem is "The thing doesn't work, and I can see a break in the wire," then soldering the gap would likely return it to a functional state. If instead the question is "Can I run a solder line across the entire thing," then sure, but the odds of it giving birds a pleasantly toasty spa experience go way down because you'll have shorted out the heating element.
