Can I use a 50 amp 240V spa panel with a 40 amp breaker in the main panel?
ctjames
New User
MN
laborer
I am running the wire for a 40 amp 240V spa that recommends the use of #8AWG THHN wire. The overall run from the main panel to the control panel on the spa is 75'. Due to cost and availability I am considering using a 50 amp 240V spa panel (GFCI disconnect). I would still be using a 40 amp double pole breaker in the main panel and #8AWG wire. Would this configuration be okay? I figure the 40 amp breaker in the main panel would protect the #8 wire and the 50 amp GFCI disconnect would protect against fault? Any help is appreciated!
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain. Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
