Can I use this switch to control a 1/2 hp 115vac motor?
ctaylo360860
colorado
ME
I have a 1/2 hp 115vac motor for an actuator. I’m wanting to use this switch to retract or extract the actuator. Basically up on the switch moves the cylinder till it hits a limit switch snd then shuts off. Put the switch in the down position and the cylinder goes down until it hits the limit switch inside the actuator housing…
Dsg319
West Virginia
Wv Master “lectrician”
Are you asking if it’s suitable for your intended use, or if the function of it will work the way you want to?
ctaylo360860
colorado
ME
I’m trying to make sure there are no code violations. I’m basically going to use the switch to control the 1/2 hp actuator up and down turn it up the actuator moves up until it hits limit switch in the cylinder and shut off. Put the switch in the down position it moves it the opposite direction until it his the second set of limit switches
