The ballast will tell you the number of lamps and how to wire them.All we have available are these four lamp T5 ballast. I was wondering if I could wire two lamps with it or do I need a two lamp ballast. Thank you for your help.
Yes, but it doesn't show if you could wire it for two lamps so I guess you can't.The ballast will tell you the number of lamps and how to wire them.
Huh? Looks like you could just use half of it and cap off what you don't use.... hopefully you're only asking for "code purposes"... is it against code? I have no idea, but this isn't exactly a brainteaser, wire-wise...Yes, but it doesn't show if you could wire it for two lamps so I guess you can't.
I just assumed, because it didn't show two lamps but I did what you said. Thank you.Huh? Looks like you could just use half of it and cap off what you don't use.... hopefully you're only asking for "code purposes"... is it against code? I have no idea, but this isn't exactly a brainteaser, wire-wise...
I'm not sure how to test one per se, never tried. I have read that some ballasts can produce over 600v and a lot of meters will not like that. Just from a quick Google search.Here's the old one. Is there anyway to test this with a meter to see if this ballast is bad?
Of course, just cap off single lamp on diagram.All we have available are these four lamp T5 ballast. I was wondering if I could wire two lamps with it or do I need a two lamp ballast. Thank you for your help.
So I did like you said, and one fixture works fine. I took another new ballast to the next fixture that wasn't working, wired it up the same way, installed two new bulbs, and when I twist the bulbs, the lights comes on for a second and shuts off. Any ideas? i'm gonna take that new ballast down and install another new ballast to see what happens.Huh? Looks like you could just use half of it and cap off what you don't use.... hopefully you're only asking for "code purposes"... is it against code? I have no idea, but this isn't exactly a brainteaser, wire-wise...
I swapped the new ballast, and put in another new ballast, and now it works, so it's a bad ballast from the factory.So I did like you said, and one fixture works fine. I took another new ballast to the next fixture that wasn't working, wired it up the same way, installed two new bulbs, and when I twist the bulbs, the lights comes on for a second and shuts off. Any ideas? i'm gonna take that new ballast down and install another new ballast to see what happens.
Actually, I messed up I put the two blues from the ballast together. Oops. lolI swapped the new ballast, and put in another new ballast, and now it works, so it's a bad ballast from the factory.![]()
Not always. Even if the label does not say so, the detailed specifications quite often allow more load variety.The ballast will tell you the number of lamps and how to wire them.
