nadprosper
OK, so I think I screwed up. I installed some 3" Halo LV cans for a client so that he could highlight some art on various walls. I installed the cans 30" from the wall ( which is standard around here ). Due to the framing of the ceiling and the aesthetics of light placement, however, the lights did not end up on the center of the art pieces. Therefore, the light is hitting too low on the art piece due to the added distance of the angle ( I went from 30" to approximately 44").
The best Halo trim allows up to 35 degrees of play....and this is now not enough. I need somewhere around 60 degrees. The client is not happy....I am not happy. Apparently, Elko makes trims with much more flexibility, but their trims do not fit into the Halo cans ( surprise ). Short of changing/moving the cans, does anyone know of a trim that would fit or another clever solution. Thanks in advance.
