stew
- federal way,washington
got a can light in a restaraunt that i service that has begun to go thru lamps twice a week . any suggestion?
I have never seen a bad thermal protector in the tens of thousands of cans I have installed. If the thermal protector was bad it would not light the bulb or it would come on and off as the unit heats and cools.Allso check if the can light has a thermal protector those can go bad as well
Tell me how that is possible other than it will turn the lights on and off and eventually burn out a bulb. A TP is nothing more than a thermostat(switch)If the thermal protector goes bad it can kill cheap lamps i have seen lots of them![]()
I don't know what brand you use but I have literally installed ten thousand or more Halo cans and I can't recall every replacing a TP. I have had them turn on and off because the bulb was not correctly sized.
I will be interested to see the results- I will still bet on the bulbs being 120V because that has been my experience.
took a while b4 i could post the answer to this issue. The hamfisted lamp replacer that does thier lamp replacements tightened to lamp too tight maybe more than once. the shell twisted and became loose from the rivets that hold it to the base. twisted just right and viola the lamp lights....... for a while until the neutral gets hot at the point of contact then I assume arcing takes the lamp out. With a meter had neutral at the point where the wire connects but not at the shell itself. New lampholder and all is well at the Red Lobster.
The can lights are not coming through with "TP's any more so that problem will go away over time.![]()
