Can multi-listed fine stranded 2/0 wire be used as building wire?
axum
New User
Denver, CO
Software Engineer
I need a short run (3 feet) of 2/0 copper from a power distribution block (inside a wireway) to a load panel but I need to make a sharp 90 degree bend from the wireway to FMC conduit. The only way this will work is to use more flexible wire than standard THHN/THHW.
Can this wire be used? https://store.polarwire.com/2-0-awg...wire-thhw-tew-mtw-awm-bc-5w2-sae-type-sgt-ct/
It's listed as THHW so my guess is yes, but I'm not sure.
Even if this allowed, how do you properly connect this wire to standard lugs? Are ferrules approved for this purpose?
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
