There is a heater inside the thermal overload which creates enough heat to cause the overload to trip if the overload is surrounded by insulation.
The heater is always on.
I saw it, but thought he wanted to get rid of them.I gotta get my eyes checked. I did not see the word "can" in the title of this thread the first time I looked at it.
Your average residential can has a thermal switch in series with the lamp inside the can. This type is usually mounted through a KO in the wiring box, bury that in insulation and it doesn't dissipate the heat it produces as quickly as if it is in open air, it cycles the light whether you have correct lamp installed or not if covered in insulation.Well that explains why the neutral is there, but are you saying the ambient air, when reaching a setpoint, causes the heater to come on thus tripping the overload or
that the heater is on all the time and when the ambient air temp is added the overload then trips?
Still don't understand why a simple switch wouldn't do the same thing
:thumbsup:
