mstrlucky74
- NJ
OK as you can seen main feeder needs to be tapped to the panel/fco sub feeders. The 225 tags are 4 #2/0 w/#4, the 100 tag is 4#2 w/#8 and the main 400 is 4#500 w/#2. I'm not clear on which conductors would be tapped/spliced together to accomplish this? Would it go like this?
1 hot #500 to each sub feeder/fco hot....this would happen four times. Thinking a Ilsco tap with one port for the 500 and 4 ports on the other side.
1 neutral #500 to each sub feeder neutral..
1 ground #2 to each sub feeder ground
How long would these splices take.
Thanks.
Thanks.
