Can UF be run exposed if not subject to damage?
Telc
Can UF be run exposed if not subject to damage, such as along the rafter of a covered porch to a light on the ceiling, UF feeder would go into a water tight fitting into a water proof box. The ceiling is 8'-9'.
I don't see any problem with that install allthough a piece of PVC- on a straight run- may make it look better
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
