110130-1332 EST
wilans:
Take a simple one cylinder pump with 100 psi back pressure (pumping into a tank with a pressure of 100 psi) and measure pump shaft torque vs angular displacement. What is your result?
Mechanically what function does a rotating mass perform?
You will find a very high peak torque requirement from the pump. Thus, high peak power requirement. That power comes from the motor and inertia of the system. A rotating mass will decrease in speed as energy is removed from the mass. The kinetic energy of a mass equals M*v^2/2 where M is the mass and v is the instantaneous velocity. The larger the mass at a given speed the greater is the energy stored. If you remove a fixed amount of energy from a moving mass then its speed must change.
A motor itself is a flywheel, but not a lot of mass. To increase this mass one adds an external flywheel. The size of the total mass will determine the speed variation of the input to the pump for a given pump load.
Suppose you drive the pump directly from the motor and the speed variation is 10%, dropping from 1800 rpm to 1620 rpm, assuming none of the energy during the torque pulse was from the motor electrical input. Now increase the inertia with a flywheel by 10 times. Now the speed fluctuation is only 1%.
In reality the motor was supplying a lot of electrical energy during the torque pulse and high forces (torques) were transmitted to the motor from the pump. With an added flywheel, and since the motor is usually coupled with a belt, there will be much less peak torque transmitted to the motor shaft. Rather the motor will have a more uniform torque load vs angular rotation. The motor will add the used energy over a much larger part of the pump cycle and at a lower peak power. This is much better for the motor and the electrical system.
The size of the flywheel will be a compromise between torque variation reduction at the motor, motor startup problems, and flywheel cost.
A little pump on a large motor and maybe no additional flywheel. A large pump on a small motor and a very large flywheel may be needed.
