The situation I'm dealing with is a sub-panel that is dedicated to feeding a hot-tub and it's related circuitry. The sub is located near the hot-tub, at the other end of the basement from the mechanical room where the main service panel is located. It's an older setup put together by a previous HO. The sub-panel is an old Federal Pacific that was red-flagged by a home inspector as being a fire hazard so the current HO wants it replaced. In the process it's become apparent that there is no GFCI protection for this hot-tub.
The circuits that the sub-panel feeds is the hot-tub heater, 2 pump motors (1 for the jets, and the other a circulating pump for the heater), and a control circuit.
I guess I'll just put the GFCI breaker in the main service panel that feeds the sub-panel, and back-feed a regular 2-pole 60a breaker (which will be the disconnect for the hot-tub) in the sub-panel. Currently the sub-panel is an MLO, so there is no single breaker acting as the disconnect. I assume the 6-switch rule doesn't apply to this situation and I need a single switch to act as the disconnect switch.
Thanks for any feedback,
Sky
