JMElectric1617
- Kansas City
- Electrician
Trying to bid a job that is sight unseen and I only have pictures to go off of. But what I have going on is a GE panel for 277/480 volt 3 phase 4 wire that is feeding a ton of rows of 277 volt fluorescent fixtures in a parking garage. This customer is wanting to had outlets for trickle chargers which will be rated for 120 volts single phase. I'm not sure if its doable or not but can I feed from a 75 amp breaker to a transformer that bucks down the voltage to install a subpanel that will then feed the required outlets that are needing 120 volts? Hopefully I am making sense...If I need to clarify anything any help on this will be much appreciated. Thanks.
