Eddy Current
I know you cant use a dimmer with CFL's but what about LED bulbs?
Best to use compatabl components.Probably best to use driver with dimming capabilities
Yes you can but you need to use a LED/CFL DIMMER SWITCH AND make sure the lamps you are using whatever type are the dimmable type.:thumbsup:I know you cant use a dimmer with CFL's but what about LED bulbs?
