Riverkid
- Portsmouth, Ohio
I had 21 HO Fixtures installed about 20 months ago on the exterior of a Drive thru store.
Seven Fixtures were placed on one side in a continious fashion, on a timed switch. I have not had to replace a bulb or a ballast on that circuit. However, the electrician installed the other 14 fixtures on two sides of the building in a strip fashion but wired the units in a candy strip fashion placing oppisite phases of the 110 source on any two fixtures. I have had to replace to date 8 ballasts and 32 lamps in these two sides of the building. The ballast are failing in pairs as well as the lamps. To me this is a no brainer. Re wire the Fixtures so only like phases of source power is resident any adjusant fixture. However the City electrical inspector has advised the owner the wiring of oppisite phase fixtures will not cause this high failure rate. I'm putting this out to the best of you all. Help
