GerryB
- woodbridge, ct. USA
Ever run into this? A large fixture, in this case quite a large chandelier, 3 feet diameter but not especially heavy, 50 lbs or so. Instead of the threaded stud supporting it and you drop the canopy and the nut down over the chain while you wire it this fixture had the bracket with two 8-32's that you mount to the ceiling box and you have to somehow wire it (need two people) then push the canopy over the 8-32's and catch with the decorative nuts they give you. Are 8-32's rated for 50lbs? I'm wondering now if they even included the right canopy with this light.
