We are building a commercial department with my boss coming out of residential (works for big home builders and bangs out couple houses a week). When I got hired I had no experience estimating or getting work. So its kinda the blind leading the blind here as far as where to even get decent leads. It seems that sites like planhub are either not showing all GC's bidding a job or the jobs are far away or out of scope. We are in Reading, PA Area trying to start out commercial, offices etc. maybe retail.
Any suggestions where to look? I am even calling around construction companies to tell them and ask for projects.
Thankful for any input
It's a tough road to break into commercial. You start out bidding GC's that you don't know and visa versa. Your number is only a check number and they have no intention of giving you the job.
Your competition is usually 10-20 EC's bidding if you use a plan service, and those GC's want all of the EC's numbers off the street. It's dead end road.
The best way to start out is to find one or two small GC's and get to know them and ask for a couple small jobs to bid. Even better if you actually know a GC friend that can help out.
Once you get a job to bid, do your best job, write up detailed proposals, cover all of the scope of work per plans/specs. You also let this GC know you are only bidding your number to him, and will not bid HIS competition.
This is part of building a relationship with this particular GC.
Once the job bids....follow up. A good GC will tell you where you were in the bid tab. Do not depend on them to call you for this. Maybe discus with GC where you went wrong on too high or too low.
Contrary to what a lot of people tell you, a good GC will never sign up an EC that is way low. A good GC doesn't want to look bad to the owner for doing so. And they especially don't look good when
subs bid low and try to nickle/dime the owner on change orders.
Once a GC gets confident in your numbers and proposals and your ability to meet bid deadlines, then comes the time where you have to give him confidence you can perform both financially, physically and technically, meet the schedules, have good job supervision, finish the job and finalize close out documents, not have any liens on his job...............once you have done all of that....he might give you another job to bid.
In commercial, it's all about your relationships with a few GC's you work for. Add GC's one at a time and treat them all special.
You said you were not good at estimating right now and that's a severe disadvantage. All of your competition uses the same vendors, special systems subs, estimating software and estimating procedures, and have
very experienced estimators on staff....most are Master electricians, former owners, former field foremen, etc
In commercial, estimating is king, and is an exact science. If you are continually too high/low you will hit the dead end road very quickly
