Re: Capacitors and Inductors
Peter -
You really don't want an engineer, you want a physicist. These are the guys and girls that understand the relationship between the Laws of God and physics and womenkind (okay - mankind too).
Engineers only understand how to use the mathematic models describing the thing they want to use - and electricals are the worst, cause the math closely fits the real world observations. The rest of the disciplines aren't that lucky.
So, given that, I have absolutely no clues as to why God (or Chaos as fitting your preference) decided this phenomena would work this way. But we have had the extraordinary good luck that physicists discovered the phenomena, did experiments to show it was repeatable, and developed the math model to describe it.
I know my explanation will sound really simplistic, but bear with me - it works for me. Snickers are acceptable and understandable - but please, save the outright laughter until the end.
Capacitors:
What they (the physicists) found was that if you separate two conductors with an insulator, that energy can be stored. If an electric source is connected across the plates, current is pumped from one plate to the other and the voltage across the plates goes up. Remove the electric source and the voltage stays - showing there is stored energy. So they came up with a unit of Capacitance that made the equation come out easy:
Q = CV where
Q = electric charge,
C = unit of capacitance
V = volts
So, if you pump charge in, voltage goes up. If charge is pumped out, voltage goes down. The bigger the capacitor, the more charge it takes to move the voltage any certain amount. Nice, linear, clean, and works every time (that's the repeatable part)
Given that, the rest is just math - okay, a touch more than High School algebra, but not much.
Lets look at what happens if we start changing the electric charge (Q) in the capacitor. The rate of change of Q, with respect to time, is the current (I). That's what current is, a movement of electric charge. We can write that as Delta(Q)/Delta(Time) = I. It is just a convention, a definition, it means Delta (Q) divided by Delta (Time), where Delta is a change, so it is a change in Q divided by the amount of time it took the electric charge to change.
If we let the time period be long, say 1 second, the charge (Q) can take really big jumps and that is hard to handle. So let the time frame be really small, so small we almost can't measure it. So we are looking at successive snapshots of the charge (Q) taken close together. Now the rate of change of the charge (Q) changes smoothly. To show that we are using small time bites, we write the equation as d(Q)/d(t) = i. the lower case letters just mean small time bites and smooth changes.
Before anybody bites me about dividing by zero, please read it to the end.
That aside, we have a major breakthrough in the math:
d(Q)/dt = i and Q = CV
Substituting for Q, d(CV)/dt = i
C is a constant, so we can take it out and get
i = C dv/dt
That says the capacitance times the rate of change of the voltage equals the current.
If we believe that to be true, that is all we need to answer the questions:
Why do capacitors oppose changes in voltage? Well they don't, they just oppose instantaneous jumps in voltage - it can be a very steep change, it just takes a lot of current. It takes energy to pump charge into a capacitor and that raises the voltage across the cap and stores the energy. When you stop pumping energy in and start letting current flow out, the voltage starts dropping. Small current flow, then small voltage change. Large current flow, large voltage change. Steep as you want, just not instantaneous.
Don't forget, when I am talking about current flowing out of a capacitor, I really mean the current is flowing out of one plate, through an external circuit, and back to the other plate.
Why does current come first with C?. Well it doesn't, but sometimes it looks like it is.
Remember the equation, i = C dv/dt. If we put a battery across the cap, then the volts are constant (unchanging) so the rate of change = 0, so the current is zero. That is what constant means, no change. Now change to a DC current source, harder to find - but available, and pump in a constant current. That means the rate of change of the voltage is constant. That means the voltage is ramping up nice and linear and just keeps climbing forever (well until the power supply crashes or we arc over in the cap). These two skull numbing, boring cases point out that the voltage is not following the current, rather the voltage is related to the current by an equation - dull but important.
Now lets put a sine wave voltage source (2V peak to peak) across the cap - this is what we see every day, 60Hz, caps, over excited synchronous motors; and the other side, reactors, induction motors.
The sine wave starts out at zero volts (0 deg), climbs smoothly to level out at the top (+1V at 90 deg), smoothly drops off to zero volts (180 deg) and continues to drop to the bottom (-1V at 270 deg), leveling out agan at the bottom, climbing back to zero (360 deg). We could have used time instead of degrees, but it gets hard to remember what part of the sine wave we are on after a few days. And the degrees keep repeating.
Now lets look at what the rate of change of the sine wave, cause that is what determines the current in the cap. At 0 deg, the sine wave is ramping up, so the rate is positive, in fact the rate happens to be 1. At 90 deg the sine wave is flattening out and turning down. Well flat is no change and the rate is zero. At 180 deg, the sine wave is headed down so the rate is negative and happens to be -1. At 270 deg the sinewave has bottomed out and the rate is again zero. At 360 deg the sine wave is headed up so the rate is positive and is +1 again.
Sketch this out and amazement will follow.
deg 0 90 180 270 360
V(sine) 0 +1 0 -1 0
I(rate) +1 0 -1 0 +1
The rate , which is the current, is the same curve as the voltage just displaced back in time by 90 deg - so the current looks like it is doing its thing right ahead of the voltage wave.
If you feed the cap with a square wave voltage source, the current is huge positive spike falling immediately to zero on the positive leading edge and a huge negative spike on the negative going trailing edge of the pulse. If you feed the cap with a triangular wave voltage source, the current is a square wave. And if you feed the cap with a sinewave, the current is a sine wave displaced back in time 90 deg.
Bit all of you, you just did some differential calculus. If you differentiate a sine wave, you get a (drum roll please) cosine wave. And the MEWs loved it.
You will have to read the next post for the divide by zero story and the MEWS definition
carl
