Car charging station q's
romex jockey
Vermont
electrician
I'm needing advice on something i've never done, a car charging station>>>
https://evbox.us/electric-cars
This will be the >>>
EVBox 1-Phase, 32A
7.4 kW
images
~RJ~
Whats to know Run a 40 amp circuit and install a receptacle- usually range receptacle or direct wire. No disconnect is necessary unless it is more than 60 amps
ah! many thx Den....lotta 'N' stuff....don't most of these take CC's? meaning cat5?
~RJ~
Granted I haven't seen all the different chargers, but I've hooked up a few different ones. As Dennis said, just a 40A or 60A circuit, depending on the requirements for the specific charger. None of the ones I installed required anything other than the specified circuit size. No Cat5 for the ones I did. Also, mine just required direct wiring but I understand there are some that come with a cord and cord cap and require a receptacle.
Some Tesla units can be wired together on the same circuit and they use the Cat 5 cable to communicate to the other units so they can control the loads at each charger being used.
Minor correction for you Dennis.....They actually use an 18/2 shielded cable between units.
