car flex
PC Chris
New member
Ft Lauderdale FL
Does any one knows if I can directly glue nonmetallic flexible conduit(car flex) in to a pvc coupling,or do I have to use a proper changeover (pvc female adapter +straight car flex connector)?
From the Carlon website:
Can you glue Carflex directly into Carlon PVC fittings?
Sorry, but fittings are not allowed to be glued or solvent-cemented to Carflex
directly. Only a mechanical connection is allowed and you can only use
Liquidtight Flexible Nonmetallic Type B fittings with our Carflex.
That's exactly correct as per 110.3(B) would require, however I have seen it done and it does hold true but it could be turned down. Not sure if it would keep the liquid tight connection. Best to do it as per manufacturers requirements
people do it, but it's not approved by the manufacturer....
it also seems the glue weakens the pvc at the bottom of
the ribs, where it's thinner....
and it would be a level ten sucky thing to have to change a whole
building out, after you'd pulled wire.....
:weeping:
It all depends on the brand of NMLTC you buy. Some of it fits perfectly into a PVC fitting, others not so much. Not that I have ever installed it that way. ;)
I have seen it done by a fairly large electrical company some time ago and it passed inspection in Bergen County NJ.
The electrician at this site told me it was acceptable. I guess the inspector looked the other way, didn't notice or based on the company's previous performances of passing, it was never actually looked at.
I can tell you that NM flex is very similar physically (rib makeup) to flexible spa hose for pool/spa plumbing applications. The glue joints are not very reliable-especially under pressure. It's basically crap for my work. Insects are known to eat through it. We don't use it.
You must have some really nasty insects where you live, I doubt I have ever seen rodents eat FNMC.
Just some nasty people:D
Termites have known to eat flexible spa hose.
I have not seen a rodents eat flexible conduit but they do chew on flexible gas lines for BBQ's. Kaboom
