Car Lift Disconnect mean required?
Yes, virtually all electrical motors do; commercial garages are no exception. However, depending on the method of wiring, the disconnect may be provided in many ways. See CEC (California Electrical Code) Art 430, Part IX beginning with Section 430.101.
:weeping: any one know car lift in commercial service garage requires a disconnect per NEC?
Yes. Where can it be located is dependent on some additional information. Most such lift applications however it must be "within sight" of the lift. If panel it is supplied from is within 50 feet and within sight then the branch circuit device could be the required disconnecting means.
