RickM15752
Anyone have experience installing low voltage wiring in outdoor cargo containers being used for storage? I've been asked to install a security system in an outdoor cargo container that has "electrical" already installed. I've not seen the job site yet. My only issue of concern is installing a small GSM cellular antenna on the outside to handle alarm reporting and I'm not sure what grounding I'll find when I go look at the job. I usually put an outdoor bell in tampered box on the exterior of a building to sound the alarm and would do the same on a cargo container. I'm not sure about grounding for the GSM antenna. It's similar to a car antenna and some folks say a separate ground is not needed while others say a separate ground is required.
This area is in California in an area that is not prone to lightning storms. My thought is that if the container has electrical, and that was done properly, then it has a grounding electrode bonding the container itself, and installing something like a mobile antenna would be sufficient ground where it penetrates the container, like a mobile install.
Or, am I missing something?
